Date/Time: Thu, 31 Oct 2024 10:13:08 +0000
SC Historical Data download failed
View Count: 638
[2016-01-02 08:16:23] |
User66292 - Posts: 12 |
It does not appear intraday data per any symbols example: A6H16 [C] 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChartHD\Data\A6H16.scid | 2016-01-02 11:11:50 and i see blank window... |
[2016-01-03 00:03:16] |
Since your account is through a broker, it does not have direct access to the "Sierra Chart Historical Data Service". You may have in the past but this is no longer the case.
