Date/Time: Sat, 19 Sep 2026 10:32:55 +0000
Each time new chartbook after "Download Current Version"
View Count: 1378
| [2016-01-02 07:44:53] |
| nicktrader - Posts: 811 |
Each time I get a new chartbook after downloading the new version. Is there a way to avoid this. My broker is "AT Infinity" |
| [2016-01-02 22:05:44] |
We see no files set to be automatically downloaded for your account. What is the exact name of this new Chartbook? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-02 22:21:29] |
As I told. In that case my broker is "Transact Infinity". I started an update and it created a new CB - called "Chartbook1". Each time I do not save it. Please see screenshot Date Time Of Last Edit: 2016-01-02 22:21:53
| [2016-01-03 08:57:27] |
This may be caused by the Infinity AT software trying to open this Chartbook even though it does not exist.
