Date/Time: Sun, 20 Sep 2026 15:38:20 +0000
[User Discussion] - set sc.FreeDLL by global constant
View Count: 1335
[2016-01-01 22:32:40]
KhaosTrader - Posts: 128
I have several studies in a cpp file, and I was wondering if I can set each of the sc.FreeDLL to a glabal scope variable such that if i am not debugging I can change the value to 0 and do a compile. This would save me having to hunt for each sc.FreeDLL and set it to 0 for deployment and then have to reset it in each place to 1 when debugging.
Thanks in advance.
[2016-01-02 04:54:08]
ejtrader - Posts: 689
You can do the following to get the result you are looking for:
on the top of the cpp file - immediately after includes - you can have the following line:
const int FREEDLL = 1;
and in defaults section:
sc.FreeDLL = FREEDLL;
Pseudo code below:
#include "sierrachart.h"
if (sc.SetDefaults) {
