Date/Time: Mon, 02 Nov 2026 08:02:39 +0000
Scanning – different timeframes
View Count: 1319
[2016-01-01 20:23:40]
User190756 - Posts: 38
Is it possible to scan a 4H-Chart while referring on daily volume?
Alert condition for example:
- the last 4H candle must exceed a certain size
- the last daily-Volume must exceed a certain value
[2016-01-01 21:05:49]
There are different ways this can be done.
One method is to also open a Historical Daily chart for the same symbol and overlay the volume from it to the 4 Hour chart by using the Study/Price Overlay study.
You will want to link the charts by Symbol, so as you scan them they remain on the same symbol. Here is the documentation for this:
http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#LinkNumber
[2016-01-02 00:50:02]
To clarify: my scan conditions on the 4H-Chart are:
=AND((H[-1]-L[-1])>1,V[-1]>7000000)
- the size of the last 4H must be > 1
- the last volume (daily chart) must be > 7000000
How can I refer the volume to the daily chart?
I have created a watch list of all S&P 500 stocks, which I want to scan
[2016-01-04 09:34:33]
We will program a study called Daily Volume which will work similar to the Daily OHLC study. Please give us a few days to have this done.
It will work on an Intraday chart instead of a Historical Daily chart. Referring to a Historical Daily chart when scanning has complications.
Date Time Of Last Edit: 2016-01-04 09:35:55
