Date/Time: Sat, 12 Sep 2026 07:20:54 +0000
Request for capability of floating chartbook
View Count: 1226
[2016-01-01 15:53:27]
User380760 - Posts: 88
Can you add function to be able to float/detach the chartbook in addition to current capability of floating/detaching a window? Thanks!
[2016-01-01 17:20:23]
User20450 - Posts: 330
+1
[2016-01-03 00:15:48]
Johnny - Posts: 99
Hello, I have also made this suggestion in the past. +1
[2016-01-03 00:19:33]
This capability is coming but indirectly through the ability of Sierra Chart to start a new instance of itself.
[2016-01-03 22:19:11]
Johnny - Posts: 99
I don't know how this will work but wouldn't it be better to provide a more direct solution like the way windows are detached?
[2016-01-03 22:44:23]
No. It is not technically possible at this time. The solution we are providing soon will distribute processing load among CPU cores and is something we can deliver now rather than two years later.
[2016-01-04 00:52:30]
Hope to be able hide menus to save space on screen. Would be great as market monitor
