Date/Time: Thu, 31 Oct 2024 10:13:01 +0000
[Locked] - Tool Bar has been renamed to Control Bar
View Count: 1396
[2016-01-01 11:18:31] |
In the newest Sierra Chart version we have now renamed Tool Bar to Control Bar. The reason this has been renamed is because the term "Tool" in Sierra Chart refers to Chart Drawing Tools which are on the Tools menu. A Tool Bar does not only contain buttons for tools but it contains buttons for all of the commands on the menus, can contain a status bar and a Watch/Symbol List control. Therefore, the proper name is "Control Bar". Microsoft also uses this terminology: https://msdn.microsoft.com/en-us/library/3d85fetk.aspx Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
