Date/Time: Thu, 31 Oct 2024 10:12:46 +0000
Change a chart bar period to seconds
View Count: 1335
[2015-12-31 21:23:22] |
idcisosf - Posts: 34 |
Hi, How to change a chart bar period to seconds, such as 10, 20 seconds? I know from Control bar bottom that I can change period to 1 min, 5 min Day, week...etc, but there is no seconds bottom. Thanks, |
[2016-01-01 11:20:56] |
There are many ways this can be done. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_ChangingPeriodOfBars.php You can also set up Control Bar buttons for your own custom time periods based on seconds. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-01 11:21:15
