Date/Time: Thu, 31 Oct 2024 10:13:09 +0000
Data Feed
View Count: 1098
[2015-12-31 03:18:36] |
User95521 - Posts: 53 |
Hi, If I have a AMP live account, Could I get Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth? Thank you! Best Regards! |
[2015-12-31 18:03:36] |
We do not fully understand the question. However, the full CME Group with Market Depth data is going to be available through futures trading services. It is also available with the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php If you want to use Sierra Chart Exchange Data Feed, you will need to use your own direct account: http://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-03 14:28:55] |
Hi, I apologize for my poor English. Many thanks for your replying. If I have an AMP live account and a direct sierrachart account, could I get full CME group with market depth data? Thank you! Best Regards! |
[2016-01-04 01:32:53] |
You can get this market data either from the trading service you will be using Or from the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Either way is fine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-04 01:45:14] |
OK, I know it. Many thanks for your help! Have a great day! |
