Date/Time: Sat, 04 Jul 2026 22:29:27 +0000
Stochastic Line Values
View Count: 1210
[2015-12-29 20:27:04]
convergence - Posts: 20
I have a stochastic setup with line value 1 at 70 and line value 2 at 30. However the stochastic itself relative to these line values change all the time. Is there a way I can keep the stochastic position the same relative to the line values?
I hope this make sense.
imagestoc.png / V - Attached On 2015-12-29 20:26:07 UTC - Size: 7.61 KB - 439 views
[2015-12-29 20:31:46]
I'm trying to think of a better way of explaining this.
If you look at the attached image, you can see that the stochastic is bent up and trying to point long. Let's say it decides to point further short, then the line values will shift up to allow the display of the stochastic to point further short.
I have seen the line values stay put with other indicators, just not sure how to make it work for me.
[2015-12-30 04:07:27]
We do not know what to suggest for this.
[2015-12-30 07:29:32]
Sawtooth - Posts: 4335
Try adding two instances of the Line study, one set to 100 and the other set to 0.
Set the Chart Region of both to the same as the Stochastic.
Date Time Of Last Edit: 2015-12-30 15:04:04
[2015-12-30 12:01:17]
tomgilb, that was EXCACTLY what I was looking for!
Thanks a million for your help on this.
