Date/Time: Fri, 27 Dec 2024 07:22:38 +0000
Hide Price On Chart Region 1
View Count: 1002
[2015-12-29 20:20:16] |
convergence - Posts: 20 |
Is there anyway to hide market price indication for chart region 1? Or do I need to put my indicator on chart region 2 and expand it?
chartregion.png / V - Attached On 2015-12-29 20:20:02 UTC - Size: 20.57 KB - 308 views |
[2015-12-29 20:25:18] |
No there is not.
[2015-12-29 20:48:26] |
Please do not say thank you. It is an unnecessary burden for us and not helpful.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-29 20:48:54
