Date/Time: Fri, 27 Dec 2024 07:21:52 +0000
Chart shows no value for pointer in the chart
View Count: 765
[2015-12-29 19:14:14]
User59217 - Posts: 13
When I moved the pointer across the chart I used to see the value of the pointer position on the right scale of the chart. After I upgraded I don't see that anymore. How can I correct this?
Thx
[2015-12-29 21:04:33]
To do this you need to use the Chart Values tool which is documented here:
http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValues
There are various options for this tool which are documented here:
http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValuesToolSettings
