Date/Time: Mon, 21 Sep 2026 00:36:15 +0000
Is S&P/TSX 60 (SXF) supported through SC data canadian feed?
View Count: 1822
[2015-12-29 08:24:14]
phaedonk - Posts: 352
https://www.m-x.ca/produits_indices_sxf_en.php
[2015-12-29 08:31:51]
Not sure just yet. We are checking on this.
[2015-12-29 20:54:15]
This is a separate exchange with a 10.50 USD exchange fee. It is the Montréal exchange.
We have to set up this exchange. That will be done in the next week.
[2016-02-22 16:26:53]
Thank you for this. However, I just set this up, restarted Sierra but cannot get data for TSE60-201603-CDE. Can you please check on this?
[2016-02-22 18:45:23]
We have now set up mapping for this symbol for Interactive Brokers.
Global Symbol Settings: Update Symbol Settings
Date Time Of Last Edit: 2016-02-22 18:45:34
[2016-03-02 14:58:28]
Can you please help me out here? I followed your instructions, am seeing data but my order was not sent to TWS.
TSE60-201603-CDE [CB] [M] 5 Min #6 | Reloading chart. | 2016-03-02 16:48:10
Symbol Error - (unknown symbol with ID 23036) is unknown, unavailable, or improperly formatted. | 2016-03-02 16:50:25
Symbol Error - (unknown symbol with ID 23037) is unknown, unavailable, or improperly formatted. | 2016-03-02 16:50:25
Symbol Error - (unknown symbol with ID 23038) is unknown, unavailable, or improperly formatted. | 2016-03-02 16:50:25
Interactive Brokers | Received Open orders end message. | 2016-03-02 16:50:41
[2016-03-02 15:00:34]
It could be that the symbol specification is not exact enough. We will add the currency and multiplier. Just give us about 10 minutes.
However, we also recommend restarting TWS to see if that makes a difference.
[2016-03-02 15:15:11]
The symbol settings have been updated for this symbol. Update the Symbol Settings on your side:
http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
This is the new symbol that you can find in File >> Find Symbol:
TSE60-######-CDE-CAD-200
Choose the particular year and month that you require and use that.
There is also a mini contract for this market with a multiplier of 50. Did you want to trade that one?
Date Time Of Last Edit: 2016-03-02 15:15:49
[2016-03-02 15:42:56]
No, the full one is fine. Thank you.
