Date/Time: Fri, 18 Sep 2026 03:45:53 +0000
Historical chart data
View Count: 973
| [2015-12-29 02:21:03] |
| User713273 - Posts: 409 |
http://www.sierrachart.com/index.php?page=doc/doc_HistoricalDownload.html Curious when having multiple historical chart data instances open, what data or memory usage is being driven. For example, if I might have 12 historical data charts open while continuing to trade intraday. |
| [2015-12-29 02:59:28] |
We do not understand the question. Please be more clear.
| [2015-12-29 05:26:03] |
When opening a historical data chart using a symbol for buy and sell entries. Im wondering the memory usage within Sierra Chart. I ask this because I'm worried that having too many historical data charts open would cause SC to crash. Hope this is clear, thx. |
| [2015-12-29 07:37:09] |
You can see the memory use through the Windows Task Manager. Sierra Chart will only have a problem if the memory use starts getting close to 4 GB. If you have a large number of charts open like 200 or more, you might have a problem with Windows itself having a problem with a large number of windows open. However, in future versions of Sierra Chart this will be better managed to greatly minimize this potential problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-29 07:39:05
