Date/Time: Sat, 11 Jan 2025 17:39:04 +0000
J29 = True, though "Confirm cancellation window" pops up in simulation mode
View Count: 1107
[2015-12-28 13:02:26]
pkhst958 - Posts: 57
Hi all,
I am experimenting with the new spreadsheets.
I use J29 to flatten before closure, so I have put a time tigger in it. When that trigger turns to "true" in Simulation mode a window pops up requesting me to confirm cancellation of all orders. Where can a turn that off? And would it happen in live trading, too?
[2015-12-28 16:21:52]
Found M bottom, case closed
[2015-12-28 17:24:46]
The confirmation window should never appear for automated trading. We need to correct that.
[2015-12-28 22:12:15]
This is very concerning:
This should not happen and we cannot duplicate this. We do not even see how this is possible.
[2016-12-24 03:06:57]
User884396 - Posts: 26
Hi there, im having trouble with some attached orders in backtesting(ACSIL) that are not getting filled so since i do not execute any trade if there is an open order after that i cannot backtest. I thought that this problem would be solved if i deactivate the option new bar at session start but it doesn't solve it. So im saving the target value and the stop value, so if the price is grater than the target for example i use this: sc.FlattenAndCancelAllOrders(); but the window pops up requesting me to confirm cancellation of all orders and i want that to be automatic.
[2016-12-24 05:48:48]
This definitely should not happen. Update Sierra Chart to the latest release and let us know if you still see this problem.
[2016-12-24 06:09:23]
We see why this happens. This will be resolved in the next release which will be out in a day or two.
For the time being disable cancel order confirmations through the Trade Window for the chart the trading system study is on.
Date Time Of Last Edit: 2016-12-24 06:09:54
[2016-12-24 15:16:00]
Thanks a lot!!!!
[2016-12-30 00:15:14]
Hello, this will be solved with 1504 version?
[2016-12-30 01:27:09]
Yes it has been.
