Date/Time: Wed, 23 Sep 2026 14:57:52 +0000
[Locked] - Price Mid-Point of Current Session?
View Count: 2448
| [2015-12-27 01:33:28] |
| Halco - Posts: 92 |
Is there any study that plots this? Thanks.
| [2015-12-27 02:01:49] |
This can be done with the Daily OHLC study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137 Refer to the subsection: Displaying Midpoint of High and Low Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-21 05:33:55] |
| kinghat - Posts: 120 |
on the Daily OHLC study if you set the width to 2(default) and want it to be dashed it doesnt show as dashed until you change it back to 1.
| [2016-03-21 05:58:14] |
This is documented here: Chart Studies: Subgraphs Tab >> Line Style Please do not ask us to solve this because we cannot. It is how it is and it will not change. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-21 05:58:30
