Date/Time: Thu, 26 Dec 2024 23:43:25 +0000
How to import Bid, Ask and Last tick data from .CSV (to be used for backtesting)?
View Count: 844
[2015-12-27 00:09:48] |
User760942 - Posts: 120 |
Is this import possible? How do I do it if so? I could not find info on how in this link https://www.sierrachart.com/index.php?page=doc/doc_TextCSVDataFormat.html thnks. |
[2015-12-27 00:44:25] |
This is the format: Date, Time, Unused, Ask, Bid, Close, Volume, Number of Trades, Bid Volume, Ask Volume (Header is required. Intraday data only.) It has now been added. Where you see "Unused" use a value of 0. Number of Trades, Bid Volume, Ask Volume can be left out. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-27 00:45:40
