Date/Time: Thu, 26 Dec 2024 23:58:54 +0000
bar range average
View Count: 1392
[2015-12-25 23:34:59] |
User190756 - Posts: 38 |
is there an indicator to display the average of the bar range (high/low) over a number of bars?
[2015-12-27 02:18:41] |
This can be done by using the Moving Average-Simple study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s2 Set the Input Data input to HL Average. It is also possible to base studies on other studies: http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-27 02:19:09
