Date/Time: Sat, 13 Sep 2025 04:46:08 +0000
Not able to access data across multiple instances of SierraChart on Win10 machine
View Count: 792
[2015-12-24 14:56:39] |
User65754 - Posts: 25 |
Hi, Re: Not able to access data across multiple instances of SierraChart on Win10 machine I recently installed two copies of SierraChart (one from my Broker Transact/Infinity ver 1336) and another of my own install from the SierraChart website (ver 1336; with a separate set of data subscriptions from the Transact install ) on a Win10 machine. I was hoping to get the data from my install into the Transact Instance. However I cannot pull down the other instance name under File->Find Symbol. This is the same behavior if I try on Transact instance or my own instance. Any guidance will be appreciated. Thanks SK. |
[2015-12-24 19:31:41] |
Refer to this section here about this: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#SharingWithAdminAccess Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
