Date/Time: Tue, 29 Sep 2026 13:44:44 +0000
Switching quantities
View Count: 895
| [2015-12-23 14:40:53] |
| User638756 - Posts: 52 |
I set my quote board up with stocks and the DOM is stuck on contracts and not shares
| [2015-12-23 18:16:58] |
This is not clear for us. A quantity can represent both contracts and shares and you can set the Order Quantity to whatever number you want. If you are referring to the Quantity Buttons, refer to: Basic Trading and the Trade Window: Main/C >> Order Quantity Buttons If you are referring to the default order quantity, then that can be set through the Global Symbol Settings: Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
