Date/Time: Fri, 27 Dec 2024 00:05:45 +0000
Adding an OCO order aFTER
View Count: 702
[2015-12-23 05:26:15] |
User638756 - Posts: 52 |
Is there a way to execute an order without using an attached order then adding an OCO order to that first order?
[2015-12-23 08:39:55] |
Yes. Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html#SendAttachedOrders You can also use this OCO order type: https://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html#OCOLimitandStop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
