Date/Time: Fri, 27 Dec 2024 15:17:53 +0000
Initial Balance Study
View Count: 1530
[2015-12-22 16:28:19] |
mkata - Posts: 103 |
Is the Initial Balance Type: Intraday working properly? When I select this option and set the Intraday Num Minutes, nothing changes; it is the same as the Daily option. I checked to see if I was using it wrong but the documentation for the Intraday option seemed to be missing.
[2015-12-22 19:12:09] |
We will accurately and thoroughly document the new Inputs with the Initial Balance study.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-22 19:12:29
[2015-12-22 19:19:38] |
For us to answer the question, post an image of the chart with the Initial Balance study. Make sure there is no other study on the chart. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-22 19:57:59] |
Here it is: http://www.sierrachart.com/image.php?l=1450814163896.png Date Time Of Last Edit: 2015-12-22 19:58:17
[2016-01-04 13:57:30] |
Are you still working on documentation?
[2016-01-04 18:14:46] |
We will have this done by the end of the day.
[2016-01-05 16:17:40] |
Here is the updated documentation for the Initial Balance study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s326 Review the Study Input descriptions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
