Date/Time: Tue, 07 Jul 2026 05:33:19 +0000
Alert sounds for when Stop is hit - Version 1335
View Count: 1259
| [2015-12-22 16:21:19] |
| trumpy - Posts: 37 |
Hi - I have an alert sound configured for when a stop is hit and it is set to "1" for number of times to play sound BUT it plays the sound for every lot that I am trading. For instance if I get stopped out and am trading 3 lots it plays the sound 3 times over. I am using attached orders and my stops are all set at the same price - "Stop All" in the targets list. Is there something I can do so that it only plays the sound once I'm not sure why it's not working? Thanks, Scott |
| [2015-12-22 18:25:11] |
This is true because there are actually three separate Stop orders if you have three separate targets. There is no way to change this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-22 18:25:31
| [2015-12-22 18:54:06] |
ok thanks for the reply. Cheers |
