Date/Time: Fri, 27 Dec 2024 01:01:20 +0000
General Use Question
View Count: 772
[2015-12-22 03:53:46] |
Sierra Chart - Max - Posts: 5768 |
1. Is there a way to have 4 charts up on 4 different monitors? Does Sierra have the Global Crosshair that will stay in the same place no matter what time frame you’re on? Level on 5 minute stays in place when looking at 240 minute chart. Is there a way to make the chart panels (windows) smaller or compress so you can move them around your screen to be able to see price action.
Sierra Chart Support Date Time Of Last Edit: 2015-12-22 20:36:32
[2015-12-22 20:35:39] |
1. Yes. The way this can be accomplished is by detaching these 4 individual charts following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html 2. Yes. Here is the documentation for the Global Cursor feature with the Chart Values tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#GlobalCursor The price level of the Chart Values crosshair will be the same among all of the charts. There should not be any problem with this. 3. Yes, select Window >> Restore to put the window in a resizable state. You can also detach a chart and resize it: https://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-22 20:37:29
