Date/Time: Mon, 14 Sep 2026 14:00:06 +0000
[User Discussion] - spreadsheet study and time
View Count: 1299
[2015-12-22 01:07:16]
User175327 - Posts: 39
hi- i am trying to write buy/sell entries based upon certain criteria being met at the open....specifically within 5 minutes of the open. i have been through several threads on the support board but cant get this to work. not sure what i am doing wrong....=AND($J$41>=TIMEVALUE("08:00:00"),($J$41<=TIMEVALUE("08:10:00"),(id0.sg4@3>id3.sg1@3)).... this is where i am. i only want the spreadsheet to look at the first 5 minutes after the open and include at least one other qualifier like the example, but i can't get it to work. any help would be super!!
[2015-12-22 04:41:02]
Sawtooth - Posts: 4352
Try this:
=AND($J$41>=TIMEVALUE("08:00:00"),$J$41<=TIMEVALUE("08:10:00"),(id0.sg4@3>id3.sg1@3)
[2015-12-23 02:43:23]
Hi, thanks for the response but that still does not seem to work. This is the current equation i am using:
=AND($J$41>=TIMEVALUE("08:00:00"),$J$41<=TIMEVALUE("08:10:00"),CROSSFROMBELOW(ID0.SG4@3:ID0.SG4@4,ID3.SG1@3:ID3.SG1@4))
the ending part works just fine all on its own but when i couple it with the time constraint it doesnt return any signals. Any ideas?!
[2015-12-23 03:57:49]
If you are expecting an arrow, it will only appear in Replay or in real time because J41 is the chart's update DateTime.
[2015-12-23 21:36:44]
It does not appear in replay as well, for some reason the time command negates any signal from occurring. I have it written exactly as above and it does not work in replay. Again, the "crossfrom...signal is fine until I add the time part to the equation.
[2015-12-23 22:05:17]
Oops. Use this instead:
=AND($J$41-INT($J$41)>=TIMEVALUE("08:00:00"),$J$41-INT($J$41)<=TIMEVALUE("08:10:00"),CROSSFROMBELOW(ID0.SG4@3:ID0.SG4@4,ID3.SG1@3:ID3.SG1@4))
J41 includes the date and time, and the TIMEVALUE function is only the time, so $J$41-INT($J$41) is needed to remove the date and leave only the time.
[2016-01-04 20:40:16]
Thank you very much!! That works and is exactly what I wanted.
Is there a way to limit the signal to only fire once per day, possibly with (J7=0) where the prior position must have equaled 0, though this does not seem to update on a per day basis, rather after each trade..... Thanks!!
[2016-01-05 00:49:58]
Take a look at this thread:
Multiple Entries
