Date/Time: Fri, 27 Dec 2024 00:25:49 +0000
How to put a initial delay for acsil study.......
View Count: 917
[2015-12-21 19:44:32] |
User368248 - Posts: 46 |
Hello. I am building a hedge system buy/sell interbroker ( 2 instances ). I want to put a initial delay on both acsil studys, lets say 30 seconds. This its due I want both studies get stables before start togheter. I am looking for "delay, sleep" functions can not find it. Can you give a tip how to do this initial delay ? Thanks in advance |
[2015-12-21 20:35:14] |
Use sc.UpdateAlways and keep track of the elapsed time before performing whatever action you want to do after the delay. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scUpdateAlways Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
