Date/Time: Fri, 27 Dec 2024 01:01:07 +0000
Looking for a simple Range alert
View Count: 635
[2015-12-21 16:08:59] |
User268341 - Posts: 15 |
Hi, Looking for a alert that when there is at least 3 red down bars in a range 2 chart and than a green bar I will be alerted. As well as the inverse, at least 3 green up bars in a range 2 chart and than a red bar alert. Thank you. |
[2015-12-21 17:57:25] |
Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php Refer to the examples on that page as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
