Date/Time: Thu, 26 Dec 2024 20:10:04 +0000
thinkorswim integration
View Count: 1698
[2015-12-21 01:38:03] |
User380760 - Posts: 88 |
I have a few questions about thinkorswim integration with sierra chart - do you need thinkorswim to run in background like interactive brokers? - is it possible to trade on paper account with thinkorswim? - is there separate current symbol (eg like interactive brokers) to use for thinkorswim? Thanks! |
[2015-12-21 01:52:18] |
First, did you want to trade futures or stocks with Think or Swim/TD Ameritrade? The integration Sierra Chart has with TD Ameritrade really is not that good. Interactive Brokers is significantly better even though that has its problems. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-21 01:52:42
