Date/Time: Tue, 26 Nov 2024 13:32:25 +0000
Can you put "Hide value scales" under the available list of Customize Chart Shortcut M
View Count: 1300
[2015-12-21 00:31:11]
User380760 - Posts: 88
I freq hide value scale (under chart setting>>advanced setting). It's very cumbersome to go into "chart setting" to change. Can you put this option under the list of "customize chart shortcut menu"? Thanks for the help.
[2016-01-04 20:33:19]
up
[2016-01-04 20:42:34]
We are not accepting new suggestions now. Even if you were to pay for this.
Date Time Of Last Edit: 2016-01-04 20:42:52
[2020-11-13 16:45:29]
whats1thingnow - Posts: 407
i frequently unhide and 'hide values scale'
it is taking so many clicks in my day to go to chart setting>>advanced setting and check and uncheck this little box
is there a way to add a keyboard shortcut please?
