Date/Time: Thu, 26 Dec 2024 20:28:56 +0000
weekly chart extra open
View Count: 721
[2015-12-20 17:44:19] |
User63632 - Posts: 43 |
http://www.sierrachart.com/image.php?l=1450632679971.png Having problem getting a weekly chart regular trading session for ES. Have followed instructions precisely. The high,low, Open, Close, are right, but some weekly bars have a extra open and bar range may be green and red ( example week 11/30). Chart settings: Date range begins 2014-06-08, which is a Sunday and end date is blank, also session time is 9:30-16:14:59, use evening session is unchecked, intra day only, bar period 7-0-0 Please advise Thanks |
[2015-12-20 20:37:06] |
What did you do wrong that is causing the problem? Hint: Check the studies on the chart and the settings for those studies. Based on what we see in the chart image, this is the most amount of information we can provide. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
