Date/Time: Thu, 26 Dec 2024 20:05:35 +0000
Forex data for two weeks only?
View Count: 774
[2015-12-20 03:26:56] |
User380760 - Posts: 88 |
In the documentation, it said that "Sierra Chart Real Time and Historical Forex and CFD Data Service" is included in the standard packages. But why I can only download two weeks of data from 12/3 to 12/18 on daily chart for GBP/JPY? and only 5/2015 to 12/2015 for EUR/USD?
[2015-12-20 05:08:47] |
What Data or Trading service is Sierra Chart set to use (Global Settings >> Data/Trade Service Settings)? What are the exact symbols that you are using? We need the exact symbols being used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-20 05:19:15] |
I set interactive brokers for trading service. The symbol that I used is GBPJPY and EURUSD (not interactive broker's idealpro), shown as GBPJPY[M] and EURUSD[M] |
2015-12-20_0-18-26.png / V - Attached On 2015-12-20 05:19:00 UTC - Size: 117.78 KB - 286 views 2015-12-20_0-17-01.png / V - Attached On 2015-12-20 05:19:04 UTC - Size: 117.27 KB - 268 views 2015-12-20_0-14-39.png / V - Attached On 2015-12-20 05:19:11 UTC - Size: 111.39 KB - 271 views |
[2015-12-20 05:23:12] |
For daily charts select Chart >> Bar Periods >> Daily. You will get at least 10 years of data. All of those screenshots indicate you are using Intraday chart data. To increase the amount of Intraday data, refer to this section: http://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
