Date/Time: Thu, 26 Dec 2024 20:13:42 +0000
UDP example app
View Count: 788
[2015-12-19 16:10:42] |
calitrader - Posts: 28 |
Hi I am getting an error trying to compile the UDP interface example. I tried adding the SC dll in the top of the program like the error message complained about. Should I have the full path to the file hard coded into the cpp? I have attached the source file. Thank you. Chris |
udp_test.cpp - Attached On 2015-12-19 16:08:26 UTC - Size: 1.41 KB - 354 views |
