Date/Time: Thu, 26 Dec 2024 19:46:25 +0000
"Save as Region" scale setting chop off top and bottom bars
View Count: 770
[2015-12-18 22:18:22]
User380760 - Posts: 88
Attached are two images. One with the scale setting to "Save as Region", the other was automatic scale setting. In this example, the bottom bars are only shown half when "Save as Region" is chosen. I see top bars are also chopped off as well frequently.
imageautomatic range.png / V - Attached On 2015-12-18 22:18:12 UTC - Size: 47.85 KB - 297 views
image2015-12-18_17-12-02.png / V - Attached On 2015-12-18 22:18:17 UTC - Size: 48.49 KB - 292 views
[2015-12-19 00:37:45]
this is another example. note that both top bars and bottom bars are cut off.
image2015-12-18_19-36-28.png / V - Attached On 2015-12-19 00:37:41 UTC - Size: 51.63 KB - 281 views
[2015-12-19 00:53:58]
Refer to the documentation for Same as Region Scale Range type:
https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html
