Date/Time: Thu, 26 Dec 2024 20:22:34 +0000
BackTesting
View Count: 1482
[2015-12-18 21:10:00] |
AP - Posts: 117 |
Personally, I find it very difficult to get started with backtesting in simulation mode since SC does not have any videos as to how best to use it at least get the folks get started. In that light - below qs - 1. If I am testing simple strategies, although multiple ones, like mix of RSI, MA and Ask Bid Volume data - what is the best to back test with - bar based or replay back testing? 2. Do I need to use spreadsheet trading system to back test strategies effectively or should I ask is it a better way to back test? 3. Can you direct me to any online (like Infinity futures you tube line or something) which explains in a video recorded format as to how to back test using SC tools? |
[2015-12-18 21:36:45] |
1. Use Bar Based Back Testing. It is the most fastest and simple. 2. Using the Spreadsheet System for Trading study is the easiest way to construct a trading system. 3. There are no videos from us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-18 21:58:24] |
AP - Posts: 117 |
ok - thanks On #2 though - Does SpreadSheet system for Trading help back test as well? and in that case do I still use bar based back testing? |
[2015-12-18 22:02:25] |
The Spreadsheet System for Trading study in and of itself does not perform any back testing so you still have to use Bar Based back testing with it.
