Date/Time: Thu, 26 Dec 2024 20:13:20 +0000
Drawings
View Count: 712
[2015-12-18 16:38:41] |
User39772 - Posts: 311 |
Is it possible to enter Drawings/Text into a chart and attach it to the chart even if the symbols are chaged, so that the drwing/text stays in the chart ?
[2015-12-18 17:30:27] |
Yes, refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ShowingDrawingsforDifferentSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
