Date/Time: Thu, 26 Dec 2024 19:39:28 +0000
Rollover message
View Count: 964
[2015-12-18 12:03:56] |
User52538 - Posts: 11 |
How can I switch off the on-chart message "Symbol needs to rollover. Click to rollover"? I often open old contracts and this message on all charts is annoying |
[2015-12-18 17:13:29] |
This can be done by removing the Rollover rules for the symbol in Global Settings >> Symbol Settings.
