Date/Time: Thu, 26 Dec 2024 19:52:43 +0000
Connection issue
View Count: 733
[2015-12-18 08:04:47]
User938955 - Posts: 10
No connection on AMP real time data. The AMP service tried all to connect but the problem is with Sierra Chart. I'm still waiting for the help about this problem. I hope you can help me with this as soon as possible.
[2015-12-18 08:28:27]
Provide a copy of the Message Log by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
[2015-12-18 16:49:47]
Software version: 1336 | 2015-12-18 23:41:30
Uses New Spreadsheets | 2015-12-18 23:41:30
Enabled for: Advanced Features. | 2015-12-18 23:41:30
Enabled for: Sierra Chart Historical Data Service. | 2015-12-18 23:41:30
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-12-18 23:41:30
Current selected Data/Trading service: AMP/TTNet | 2015-12-18 23:41:30
Chart Update Interval: 500 | 2015-12-18 23:41:30
Time Zone: +07:00:00 (WIT+07) | 2015-12-18 23:41:30
2015-12-19 00:41:30 Local computer time | 2015-12-18 23:41:30
2015-12-18 16:41:30 Local computer time in UTC | 2015-12-18 23:41:30
2015-12-18 23:41:30 Local computer time in SC Time Zone | 2015-12-18 23:41:30
Program path: C:\SierraChart\ | 2015-12-18 23:41:30
Data Files path: C:\SierraChart\Data\ | 2015-12-18 23:41:30
OS Version Number: 6.1 | 2015-12-18 23:41:30
Locale Information: C | 2015-12-18 23:41:30
Checking for new symbol settings for tt | 2015-12-18 23:41:30
AMP/TTNet | Connecting. | 2015-12-18 23:41:35
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:41:35
HTTPS connection to www.sierrachart.com:443 (0) | Error on address resolution. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2015-12-18 23:41:53
HTTP request for symbol settings MD5 for TT FIX failed. | 2015-12-18 23:41:53
TT FIX Data socket (1) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2015-12-18 23:41:56
TT FIX Data socket (1) | Shutdown and closed. | 2015-12-18 23:41:56
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-12-18 23:41:56
TT FIX Data: Disconnected. | 2015-12-18 23:41:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:41:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:41:56
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:41:56
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:41:56
AMP/TTNet | Disconnected. | 2015-12-18 23:41:56
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:41:56
AMP/TTNet | Connecting. | 2015-12-18 23:42:01
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:42:01
TT FIX Data socket (2) | Connected. | 2015-12-18 23:42:05
TT FIX Data: Sending the Logon message. | 2015-12-18 23:42:05
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:42:05
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:42:05
TT FIX Data socket (2) | Shutdown and closed. | 2015-12-18 23:42:05
TT FIX Data: Disconnected. | 2015-12-18 23:42:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:42:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:42:05
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:42:05
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:42:05
AMP/TTNet | Disconnected. | 2015-12-18 23:42:05
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:42:05
AMP/TTNet | Connecting. | 2015-12-18 23:42:10
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:42:10
TT FIX Data socket (3) | Connected. | 2015-12-18 23:42:10
TT FIX Data: Sending the Logon message. | 2015-12-18 23:42:11
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:42:11
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:42:11
TT FIX Data socket (3) | Shutdown and closed. | 2015-12-18 23:42:11
TT FIX Data: Disconnected. | 2015-12-18 23:42:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:42:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:42:11
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:42:11
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:42:11
AMP/TTNet | Disconnected. | 2015-12-18 23:42:11
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:42:11
AMP/TTNet | Connecting. | 2015-12-18 23:42:16
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:42:16
TT FIX Data socket (4) | Connected. | 2015-12-18 23:42:18
TT FIX Data: Sending the Logon message. | 2015-12-18 23:42:18
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:42:20
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:42:20
TT FIX Data socket (4) | Shutdown and closed. | 2015-12-18 23:42:20
TT FIX Data: Disconnected. | 2015-12-18 23:42:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:42:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:42:20
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:42:20
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:42:20
AMP/TTNet | Disconnected. | 2015-12-18 23:42:20
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:42:20
AMP/TTNet | Connecting. | 2015-12-18 23:42:25
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:42:25
TT FIX Data socket (5) | Connected. | 2015-12-18 23:42:26
TT FIX Data: Sending the Logon message. | 2015-12-18 23:42:26
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:42:26
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:42:26
TT FIX Data socket (5) | Shutdown and closed. | 2015-12-18 23:42:26
TT FIX Data: Disconnected. | 2015-12-18 23:42:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:42:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:42:26
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:42:26
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:42:26
AMP/TTNet | Disconnected. | 2015-12-18 23:42:26
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:42:26
AMP/TTNet | Connecting. | 2015-12-18 23:42:31
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:42:31
TT FIX Data socket (6) | Connected. | 2015-12-18 23:42:31
TT FIX Data: Sending the Logon message. | 2015-12-18 23:42:32
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:42:32
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:42:32
TT FIX Data socket (6) | Shutdown and closed. | 2015-12-18 23:42:32
TT FIX Data: Disconnected. | 2015-12-18 23:42:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:42:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:42:32
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:42:32
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:42:32
AMP/TTNet | Disconnected. | 2015-12-18 23:42:32
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:42:32
AMP/TTNet | Connecting. | 2015-12-18 23:42:37
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:42:37
TT FIX Data socket (7) | Connected. | 2015-12-18 23:42:37
TT FIX Data: Sending the Logon message. | 2015-12-18 23:42:37
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:42:38
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:42:38
TT FIX Data socket (7) | Shutdown and closed. | 2015-12-18 23:42:38
TT FIX Data: Disconnected. | 2015-12-18 23:42:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:42:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:42:38
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:42:38
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:42:38
AMP/TTNet | Disconnected. | 2015-12-18 23:42:38
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:42:38
AMP/TTNet | Connecting. | 2015-12-18 23:42:43
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:42:43
TT FIX Data socket (8) | Connected. | 2015-12-18 23:42:43
TT FIX Data: Sending the Logon message. | 2015-12-18 23:42:43
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:42:44
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:42:44
TT FIX Data socket (8) | Shutdown and closed. | 2015-12-18 23:42:44
TT FIX Data: Disconnected. | 2015-12-18 23:42:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:42:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:42:44
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:42:44
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:42:44
AMP/TTNet | Disconnected. | 2015-12-18 23:42:44
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:42:44
AMP/TTNet | Connecting. | 2015-12-18 23:42:49
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:42:49
TT FIX Data socket (9) | Connected. | 2015-12-18 23:42:49
TT FIX Data: Sending the Logon message. | 2015-12-18 23:42:49
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:42:50
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:42:50
TT FIX Data socket (9) | Shutdown and closed. | 2015-12-18 23:42:50
TT FIX Data: Disconnected. | 2015-12-18 23:42:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:42:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:42:50
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:42:50
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:42:50
AMP/TTNet | Disconnected. | 2015-12-18 23:42:50
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:42:50
AMP/TTNet | Connecting. | 2015-12-18 23:42:55
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:42:55
TT FIX Data socket (10) | Connected. | 2015-12-18 23:42:55
TT FIX Data: Sending the Logon message. | 2015-12-18 23:42:56
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:43:01
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:43:01
TT FIX Data socket (10) | Shutdown and closed. | 2015-12-18 23:43:01
TT FIX Data: Disconnected. | 2015-12-18 23:43:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:43:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:43:01
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:43:01
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:43:01
AMP/TTNet | Disconnected. | 2015-12-18 23:43:01
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:43:01
AMP/TTNet | Connecting. | 2015-12-18 23:43:06
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:43:06
TT FIX Data socket (11) | Connected. | 2015-12-18 23:43:10
TT FIX Data: Sending the Logon message. | 2015-12-18 23:43:10
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:43:14
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:43:14
TT FIX Data socket (11) | Shutdown and closed. | 2015-12-18 23:43:14
TT FIX Data: Disconnected. | 2015-12-18 23:43:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:43:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:43:14
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:43:14
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:43:14
AMP/TTNet | Disconnected. | 2015-12-18 23:43:14
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:43:14
AMP/TTNet | Connecting. | 2015-12-18 23:43:19
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:43:19
TT FIX Data socket (12) | Connected. | 2015-12-18 23:43:20
TT FIX Data: Sending the Logon message. | 2015-12-18 23:43:20
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:43:21
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:43:21
TT FIX Data socket (12) | Shutdown and closed. | 2015-12-18 23:43:21
TT FIX Data: Disconnected. | 2015-12-18 23:43:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:43:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:43:21
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:43:21
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:43:21
AMP/TTNet | Disconnected. | 2015-12-18 23:43:21
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:43:21
AMP/TTNet | Connecting. | 2015-12-18 23:43:26
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:43:26
TT FIX Data socket (13) | Connected. | 2015-12-18 23:43:26
TT FIX Data: Sending the Logon message. | 2015-12-18 23:43:26
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:43:27
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:43:27
TT FIX Data socket (13) | Shutdown and closed. | 2015-12-18 23:43:27
TT FIX Data: Disconnected. | 2015-12-18 23:43:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:43:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:43:27
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:43:27
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:43:27
AMP/TTNet | Disconnected. | 2015-12-18 23:43:27
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:43:27
AMP/TTNet | Connecting. | 2015-12-18 23:43:32
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:43:32
TT FIX Data socket (14) | Connected. | 2015-12-18 23:43:34
TT FIX Data: Sending the Logon message. | 2015-12-18 23:43:35
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:43:37
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:43:37
TT FIX Data socket (14) | Shutdown and closed. | 2015-12-18 23:43:37
TT FIX Data: Disconnected. | 2015-12-18 23:43:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:43:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:43:37
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:43:37
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:43:37
AMP/TTNet | Disconnected. | 2015-12-18 23:43:37
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:43:37
AMP/TTNet | Connecting. | 2015-12-18 23:43:42
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:43:42
TT FIX Data socket (15) | Connected. | 2015-12-18 23:43:43
TT FIX Data: Sending the Logon message. | 2015-12-18 23:43:44
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:43:49
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:43:49
TT FIX Data socket (15) | Shutdown and closed. | 2015-12-18 23:43:49
TT FIX Data: Disconnected. | 2015-12-18 23:43:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:43:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:43:49
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:43:49
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:43:49
AMP/TTNet | Disconnected. | 2015-12-18 23:43:49
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:43:49
AMP/TTNet | Connecting. | 2015-12-18 23:43:54
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:43:54
TT FIX Data socket (16) | Connected. | 2015-12-18 23:43:57
TT FIX Data: Sending the Logon message. | 2015-12-18 23:43:57
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:43:58
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:43:58
TT FIX Data socket (16) | Shutdown and closed. | 2015-12-18 23:43:58
TT FIX Data: Disconnected. | 2015-12-18 23:43:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:43:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:43:58
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:43:58
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:43:58
AMP/TTNet | Disconnected. | 2015-12-18 23:43:58
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:43:58
AMP/TTNet | Connecting. | 2015-12-18 23:44:03
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:44:03
TT FIX Data socket (17) | Connected. | 2015-12-18 23:44:07
TT FIX Data: Sending the Logon message. | 2015-12-18 23:44:08
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:44:11
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:44:11
TT FIX Data socket (17) | Shutdown and closed. | 2015-12-18 23:44:11
TT FIX Data: Disconnected. | 2015-12-18 23:44:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:44:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:44:11
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:44:11
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:44:11
AMP/TTNet | Disconnected. | 2015-12-18 23:44:11
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:44:11
AMP/TTNet | Connecting. | 2015-12-18 23:44:16
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:44:16
TT FIX Data socket (18) | Connected. | 2015-12-18 23:44:19
TT FIX Data: Sending the Logon message. | 2015-12-18 23:44:19
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:44:25
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:44:25
TT FIX Data socket (18) | Shutdown and closed. | 2015-12-18 23:44:25
TT FIX Data: Disconnected. | 2015-12-18 23:44:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:44:25
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:44:25
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:44:25
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:44:25
AMP/TTNet | Disconnected. | 2015-12-18 23:44:25
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:44:25
AMP/TTNet | Connecting. | 2015-12-18 23:44:30
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:44:30
TT FIX Data socket (19) | Connected. | 2015-12-18 23:44:32
TT FIX Data: Sending the Logon message. | 2015-12-18 23:44:33
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:44:35
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:44:35
TT FIX Data socket (19) | Shutdown and closed. | 2015-12-18 23:44:35
TT FIX Data: Disconnected. | 2015-12-18 23:44:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:44:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:44:35
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:44:35
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:44:35
AMP/TTNet | Disconnected. | 2015-12-18 23:44:35
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:44:35
AMP/TTNet | Connecting. | 2015-12-18 23:44:40
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:44:40
TT FIX Data socket (21) | Connected. | 2015-12-18 23:44:42
TT FIX Data: Sending the Logon message. | 2015-12-18 23:44:42
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:44:46
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:44:46
TT FIX Data socket (21) | Shutdown and closed. | 2015-12-18 23:44:46
TT FIX Data: Disconnected. | 2015-12-18 23:44:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:44:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:44:46
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:44:46
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:44:46
AMP/TTNet | Disconnected. | 2015-12-18 23:44:46
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:44:46
AMP/TTNet | Connecting. | 2015-12-18 23:44:51
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:44:51
TT FIX Data socket (22) | Connected. | 2015-12-18 23:44:54
TT FIX Data: Sending the Logon message. | 2015-12-18 23:44:54
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:44:57
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:44:57
TT FIX Data socket (22) | Shutdown and closed. | 2015-12-18 23:44:57
TT FIX Data: Disconnected. | 2015-12-18 23:44:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:44:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:44:57
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:44:57
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:44:57
AMP/TTNet | Disconnected. | 2015-12-18 23:44:57
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:44:57
AMP/TTNet | Connecting. | 2015-12-18 23:45:02
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:45:02
TT FIX Data socket (23) | Connected. | 2015-12-18 23:45:06
TT FIX Data: Sending the Logon message. | 2015-12-18 23:45:07
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:45:12
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:45:12
TT FIX Data socket (23) | Shutdown and closed. | 2015-12-18 23:45:12
TT FIX Data: Disconnected. | 2015-12-18 23:45:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:45:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:45:12
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:45:12
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:45:12
AMP/TTNet | Disconnected. | 2015-12-18 23:45:12
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:45:12
AMP/TTNet | Connecting. | 2015-12-18 23:45:17
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:45:17
TT FIX Data socket (24) | Connected. | 2015-12-18 23:45:19
TT FIX Data: Sending the Logon message. | 2015-12-18 23:45:19
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:45:24
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:45:24
TT FIX Data socket (24) | Shutdown and closed. | 2015-12-18 23:45:24
TT FIX Data: Disconnected. | 2015-12-18 23:45:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:45:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:45:24
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:45:24
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:45:24
AMP/TTNet | Disconnected. | 2015-12-18 23:45:24
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:45:24
AMP/TTNet | Connecting. | 2015-12-18 23:45:29
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:45:29
TT FIX Data socket (25) | Connected. | 2015-12-18 23:45:30
TT FIX Data: Sending the Logon message. | 2015-12-18 23:45:30
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:45:34
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:45:34
TT FIX Data socket (25) | Shutdown and closed. | 2015-12-18 23:45:34
TT FIX Data: Disconnected. | 2015-12-18 23:45:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:45:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:45:34
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:45:34
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:45:34
AMP/TTNet | Disconnected. | 2015-12-18 23:45:34
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:45:34
AMP/TTNet | Connecting. | 2015-12-18 23:45:39
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:45:39
TT FIX Data socket (26) | Connected. | 2015-12-18 23:45:42
TT FIX Data: Sending the Logon message. | 2015-12-18 23:45:42
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:45:43
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:45:43
TT FIX Data socket (26) | Shutdown and closed. | 2015-12-18 23:45:43
TT FIX Data: Disconnected. | 2015-12-18 23:45:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:45:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:45:43
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:45:43
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:45:43
AMP/TTNet | Disconnected. | 2015-12-18 23:45:43
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:45:43
AMP/TTNet | Connecting. | 2015-12-18 23:45:48
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:45:48
TT FIX Data socket (27) | Connected. | 2015-12-18 23:45:49
TT FIX Data: Sending the Logon message. | 2015-12-18 23:45:50
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:45:51
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:45:51
TT FIX Data socket (27) | Shutdown and closed. | 2015-12-18 23:45:51
TT FIX Data: Disconnected. | 2015-12-18 23:45:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:45:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:45:51
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:45:51
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:45:51
AMP/TTNet | Disconnected. | 2015-12-18 23:45:51
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:45:51
AMP/TTNet | Connecting. | 2015-12-18 23:45:56
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:45:56
TT FIX Data socket (28) | Connected. | 2015-12-18 23:45:57
TT FIX Data: Sending the Logon message. | 2015-12-18 23:45:57
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:45:58
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:45:58
TT FIX Data socket (28) | Shutdown and closed. | 2015-12-18 23:45:58
TT FIX Data: Disconnected. | 2015-12-18 23:45:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:45:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:45:58
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:45:58
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:45:58
AMP/TTNet | Disconnected. | 2015-12-18 23:45:58
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:45:58
AMP/TTNet | Connecting. | 2015-12-18 23:46:03
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:46:03
TT FIX Data socket (29) | Connected. | 2015-12-18 23:46:03
TT FIX Data: Sending the Logon message. | 2015-12-18 23:46:03
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:46:04
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:46:04
TT FIX Data socket (29) | Shutdown and closed. | 2015-12-18 23:46:04
TT FIX Data: Disconnected. | 2015-12-18 23:46:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:46:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:46:04
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:46:04
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:46:04
AMP/TTNet | Disconnected. | 2015-12-18 23:46:04
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:46:04
AMP/TTNet | Connecting. | 2015-12-18 23:46:09
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:46:09
TT FIX Data socket (30) | Connected. | 2015-12-18 23:46:09
TT FIX Data: Sending the Logon message. | 2015-12-18 23:46:09
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:46:10
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:46:10
TT FIX Data socket (30) | Shutdown and closed. | 2015-12-18 23:46:10
TT FIX Data: Disconnected. | 2015-12-18 23:46:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:46:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:46:10
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:46:10
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:46:10
AMP/TTNet | Disconnected. | 2015-12-18 23:46:10
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:46:10
AMP/TTNet | Connecting. | 2015-12-18 23:46:15
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:46:15
TT FIX Data socket (31) | Connected. | 2015-12-18 23:46:15
TT FIX Data: Sending the Logon message. | 2015-12-18 23:46:15
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:46:15
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:46:15
TT FIX Data socket (31) | Shutdown and closed. | 2015-12-18 23:46:15
TT FIX Data: Disconnected. | 2015-12-18 23:46:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:46:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:46:15
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:46:15
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:46:15
AMP/TTNet | Disconnected. | 2015-12-18 23:46:15
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:46:15
AMP/TTNet | Connecting. | 2015-12-18 23:46:27
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-18 23:46:27
TT FIX Data socket (32) | Connected. | 2015-12-18 23:46:27
TT FIX Data: Sending the Logon message. | 2015-12-18 23:46:28
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-12-18 23:46:28
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-12-18 23:46:28
TT FIX Data socket (32) | Shutdown and closed. | 2015-12-18 23:46:28
TT FIX Data: Disconnected. | 2015-12-18 23:46:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-18 23:46:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-18 23:46:28
TT FIX Data: DisconnectFIX called. | 2015-12-18 23:46:28
TT FIX Trading: DisconnectFIX called. | 2015-12-18 23:46:28
AMP/TTNet | Disconnected. | 2015-12-18 23:46:28
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-18 23:46:28
[2015-12-18 17:27:20]
This is the relevant message:
The Username is referring to the Sender Comp ID. Contact your broker for this and for the password.
Follow through the set up instructions here:
https://www.sierrachart.com/index.php?page=doc/AMPTTNet.php#SetupInstructions
