Date/Time: Thu, 26 Dec 2024 20:13:35 +0000
Newbie Question - Version 1335
View Count: 732
[2015-12-18 02:16:16] |
trumpy - Posts: 37 |
Hi - I'm trying to figure out if it's possible to make a horizontal line I draw on the daily chart also appear on the 4hr, 1hr etc automatically for the same instrument? Thanks, Scott |
[2015-12-18 03:09:26] |
User62936 - Posts: 68 |
Very easy. Just go to chart settings, then advanced settings 2 tab and on the bottom right it says "copy chart drawings from..." where you just input the chart number that is your daily chart.
[2015-12-18 11:22:25] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-18 16:03:23] |
Cool thanks a lot. Cheers |
