Date/Time: Sat, 04 Jul 2026 13:22:23 +0000
ACSIL - How to force data recalculation on feed connect/disconnect?
View Count: 1257
[2015-12-18 01:10:42]
ejtrader - Posts: 689
SC Team - Is there any reliable way to force recalculate when data feed is connected/disconnected?
I have explored - sc.ServerConnectionState - but probably running into usage issues.
The following code - doesn't get executed when the feed is disconnected/connected. Would you please provide any tips on this?
if (sc.UpdateStartIndex == 0) {
sc.AddMessageToLog(" ---- testind --- update == 0 -----", 0);
thanks
[2015-12-18 18:49:16]
We can only recommend sc.ServerConnectionState.
The documentation explains here that the study function will be called whenever there is a connection or disconnection to/from the servers:
ACSIL Interface Members - Variables and Arrays: sc.ServerConnectionState
[2015-12-18 22:57:10]
Thanks SC Team.
For anyone interested - this is the solution I came up with ( whether efficient or not). This would trigger a recalc - when there is a change with the ServerConnection state.
Just wish there is such option for a chart which is remote data based. Any possibility to add this function?
int &dfStatus = sc.GetPersistentInt(1);
if (sc.UpdateStartIndex == 0 || (dfStatus != sc.ServerConnectionState && sc.ServerConnectionState == SCS_CONNECTED)) {
dfStatus = sc.ServerConnectionState;
Date Time Of Last Edit: 2015-12-19 02:58:30
