Date/Time: Mon, 14 Sep 2026 01:38:47 +0000
Data folder for installing .exe file
View Count: 1104
[2015-12-17 23:45:59]
User592524 - Posts: 5
Hello Support
I purchased an indicator which draws swing points for Sierra charts from TradingAnalysis.com. It is an .exe file and the default folder while installing is SierraChart/SierraChartTransactMA/Data
1) Is this the correct folder (just want to make sure)
2) I also get a warning from Microsoft and was afraid to install it and so exited without installing. I searched the forums but did not find my answer.
Please help how to to install the .exe file with the correct folder and how to import the indicator onto the charts
Thank you
[2015-12-18 10:46:28]
1. In your case the files need to be saved to C:\SierraChart\Data. You can find complete documentation here:
https://www.sierrachart.com/index.php?page=doc/doc_DLLUsage.html
You definitely need to use the folder we specified above.
2. What is the warning? Probably you can ignore it.
