Date/Time: Thu, 26 Dec 2024 17:50:19 +0000
Lost tool bar.
View Count: 802
[2015-12-17 22:20:58] |
User700956 - Posts: 18 |
Hello I have lost my tool bar. I detached and moved it. I do not think i deleted it, but I can't find it. When I go to rebuild a new tool bar under customize toolbar commands under tools, all I see is a list of numbers. 31 33 95 ect. How can I get my main tool bar back. Should I uninstall Sierra Charts and download a new one? Thank you Bob Johnsen
[2015-12-18 04:46:35] |
Select Window >> Reset Windows. So you see some ToolBar buttons that just contain numbers? We want to be totally clear where you see these. Could you attach a screenshot. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile If you see the numbers directly on the buttons on the Control Bar/ToolBar, then install Sierra Chart again by selecting Help >> Download Prerelease. Here are complete instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
