Date/Time: Thu, 17 Sep 2026 13:03:36 +0000
Question on Color based on Slope Study
View Count: 1773
| [2015-12-17 16:45:46] |
| AP - Posts: 117 |
Hi - I am using this Color based on Slope Study twice for 2 different indicators for one my charts. Now, I am wanting to add a Color Bar Based on Alert Condition to set an alert when both the above slopes are positive. Once I do that, I can easily hide the slope studies and the indicator studies to keep just one study on (i.e. the one that checks for positive slopes on both). Question - 1. DO you know what operators I can using to set a conditional alert to make sure both slopes are positive at the same time? 2. If 1 above is not possible, Any other indicators you know I can use to check for slope instead of using COlor Based on Slope studies? |
| [2015-12-17 18:32:53] |
1. In one of the examples here, there is one for slope: Study/Chart Alerts And Scanning: Alert Formula Examples You also need to use the AND function in the Formula: Spreadsheet Functions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
