Date/Time: Tue, 15 Sep 2026 21:37:31 +0000
TPO "Profile Time Period Length Unit"
View Count: 1162
| [2015-12-17 10:35:35] |
| User94740 - Posts: 333 |
it would be great if this parameter also had the increment of seconds. A five minute TPO has very little to offer in the way of visual impression.
| [2016-01-18 12:04:14] |
I see this has been implemented in v1347. Thank u. In order to make it effective, is it possible to change the parameter "TPO Letter/Block Time Period Length in Minutes (For Intraday Charts)?
| [2016-01-18 18:09:09] |
There are no plans to change TPO Letter/Block Time Period Length in Minutes to a lower timeframe than Minutes.
| [2016-01-18 21:41:02] |
for the TPO study, the change made to the one parameter has no meaningful effect without the change to the other parameter. Maybe it has value in other studies. ok, thx
| [2016-01-18 21:55:33] |
Yes, this change was meant for other studies like the Volume by Price study.
