Date/Time: Sun, 13 Sep 2026 22:21:20 +0000
Digital clock on chart
View Count: 3798
[2015-12-16 23:23:14]
User515532 - Posts: 19
Hi, is there a setting to display a clock with hour, minutes and second on the chart?
[2015-12-16 23:30:39]
Yes actually there is. Refer to Customize Chart Header and add the Time field if it is not already there:
Global Settings Menu: Customize Chart Header - Standard (Global Settings menu)
We probably could also put together a simple time study that also displays the real-time time.
Date Time Of Last Edit: 2015-12-16 23:31:12
[2015-12-17 08:22:39]
User13668 - Posts: 296
SC: there already is a Study under User Contributed Studies called 'Clock'.
[2015-12-17 13:15:20]
Sawtooth - Posts: 4352
That study is buggy and limited. A native SC clock/time study would be welcomed.
[2015-12-18 10:13:52]
Marmany - Posts: 319
If you have the opportunity to develop a clock study please include the functionality to generate alerts i.e. use as an alarm clock.
[2015-12-18 10:40:57]
In the next release you will see a new study named "Clock - Real Time".
[2020-10-29 16:39:02]
User00111 - Posts: 111
The "Clock - Real Time" function gives me the Italian time ... without changing Time Zone it is possible to get the Chicago time ?
A.
[2020-10-29 17:20:17]
John - SC Support - Posts: 47854
We have updated the study to include an Hour Offset Input that will allow you to set an offset from the current time so you can display a different time zone. This will be in the next Pre-Release (v 2190). When available, you can update using the Fast Update option:
