Date/Time: Thu, 26 Dec 2024 17:48:55 +0000
Order Quantity 10000 show diferent value in profit on 2 diferent forex brokers...
View Count: 766
[2015-12-16 20:03:00] |
User368248 - Posts: 46 |
Hello, based on image supplied with 2 forex brokers: On broker1 I used in acsil code orderquantity = 10000 ( asuming 0.1 standart lots ), If I lost 2.4 pips then show me loss by -24000 usd. On broker2 I used orderquantity = 10000 ( same as broker1 ), If I win 1.6 pips then show me 1.6 USD profit ( I think this its correct ) Why its showing diferent values with same lotsize/order quantity? Thanks in advance |
order_qtn_error.PNG / V - Attached On 2015-12-16 20:02:10 UTC - Size: 59.8 KB - 273 views |
[2015-12-16 20:19:12] |
This has to be approached differently. If there is a particular Profit/Loss value which is not correct, then explain where it is, and tell us the symbol. Also refer to this section here: https://www.sierrachart.com/index.php?page=doc/helpdetails77.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
