Date/Time: Thu, 26 Dec 2024 18:07:25 +0000
auto reconnect feature
View Count: 723
[2015-12-16 15:57:30] |
markuz - Posts: 90 |
Is there a setting I can adjust for Sierra to auto reconnect after the globex session reopens at 5:00 pm central? I get the disconnect at 4:30 when the platform goes down for the globex close, but i manually do not want to have to reconnect on the 5:00 pm open. Thanks. |
[2015-12-16 18:32:06] |
Refer to the documentation about this here: https://www.sierrachart.com/index.php?page=doc/TransAct.php#AutomaticReconnect Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
