Date/Time: Thu, 26 Dec 2024 18:00:58 +0000
How to display Entry DateTime & Exit DateTime with milliseconds ?
View Count: 889
[2015-12-16 15:38:06] |
User368248 - Posts: 46 |
Hello. I need to see the time in milliseconds in "Trade Activity Log" reports, how can I do that? Thanks! |
[2015-12-16 19:23:32] |
We need to check on this. Where are you getting the Entry DateTime & Exit DateTime values from?
[2015-12-16 19:44:09] |
Sorry, not sure about you question, I just open "Trade Activity Log" on trade menu. Is this your question ? I dont have code in my acsil file referencing to DateTimes.
[2015-12-16 20:20:59] |
We understand. Those Date-Times do not display milliseconds. The milliseconds are only used as a counter in the Trade Activity Log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-17 00:35:39] |
Thanks, I need to record/log the date of this events : 1.- When I send a buy/sell order to fxcm broker 2.- When The broker confirm no error ( or already accepted ) the order 3.- When I sent a close/exit for such order 4.- When the broker accepted/trade such close/exit. How can I record this log but with milliseconds precision? Thanks in advance. |
