Date/Time: Thu, 26 Dec 2024 18:00:01 +0000
Alert Sound for Study
View Count: 745
[2015-12-16 14:25:40] |
User28914 - Posts: 87 |
If I want an alert sound to go off whenever a Swing Hi or Swing Low arrow is printed, what condition do I use?
[2015-12-16 19:41:30] |
What is the Length Input with that study set to? We need to know to be able to give you a formula to use. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-16 19:43:19] |
The Length Input is 2.
[2015-12-17 18:01:30] |
This is the Alert Condition Formula to use for the Swing High and Low study: =OR(SG1 > 0, SG2 > 0, SG0[-1] > 0, SG1[-1] > 0, SG0[-2] > 0, SG1[-2] > 0, SG0[-3] > 0, SG1[-3] > 0) We will add this as an example to the documentation as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-17 18:01:40
