Date/Time: Fri, 27 Dec 2024 00:33:41 +0000
Gene Sheldon
View Count: 858
[2015-12-16 13:03:10] |
User72965 - Posts: 115 |
Sending chart... The small letters in the over night are opening on the 1/4 hour <> NOT ON THE HOUR OR 1/2 HOUR As they are supposed too ?? The Day (Cap.'s A to N are ok ) Single Profile Start&End Time ???? Custom Sub Period 1 or 2 Start &End Time ?? Thinking something in these is not right to make letter columns open and close on the hour and half hour . They now do on the 15 minute time..? u just opened @ 5:45 <> Should open @ 6:00 a.m. ?? http://www.sierrachart.com/image.php?l=1450270055652.png With market Delta Charts > When I sent these images ,They could go in and examine the settings & what is needed to correct the problem .. Settings I Got Single Profile Start =1/1/2015 " " End = 12/30/15 Custom Sub 1 Start 07:29:59 " " 1 End 14:15:00 " " 2 Start 14:15:01 " " 2 End 07:29:59 Hope this helps Thx Gene :) I closed out the old TPO charts from C.Book. This chart posted is a new chart .. |
[2015-12-16 17:33:17] |
What are the Session Times you have sent in the chart? Refer to: https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-16 18:11:16] |
Session times are 2 ... 1 The closed session Over Night Runs from 4:00 p.m. to 9:30 a.m. following day. And the Day session 9:30 a.m. to 4:00 p.m. same day Thx Gene :) The cap. letters in the over night =N.Y. session ... The lower case Asia and Europe . These are the one's off by 15 minutes ~~~~ |
[2015-12-22 03:57:38] |
The way that this is presented to us is very confusing. Set the the Input Use Custom Sub Periods 1 and 2 to No. We see no reason why that is set to Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-22 03:58:01
