Date/Time: Thu, 26 Dec 2024 18:00:57 +0000
CandleStick Patterns Finder study malfunctions
View Count: 1251
[2015-12-16 01:19:36] |
rhovega - Posts: 279 |
Hi, I have added two CandleStick Patterns Finder studies to a chart, to display more than 6 patterns. The chart fails to show both studies. When I add the second, it shows the patterns/codes of the 2nd briefly, and then they disappear. I uploaded a small video showing the issue. Have two studies loaded. Neither is hidden. But only one is showing up. Whenever a click on Apply, the one study that is not visible briefly shows the patterns, and then they disappear. Can you please help with this? Furthermore, could you consider modifying the study so the user may choose if s/he wants the pattern codes to show above or below the bars? This would be useful for differentiating between bullish and bearish patterns. (turning the distance between codes and bars to negatives does not do the job). Thanks |
[2015-12-16 01:20:27] |
Video uploaded ... just a few secs long.
2015-12-15_20-10-57.mp4 - Attached On 2015-12-16 01:19:53 UTC - Size: 1.49 MB - 550 views |
[2015-12-16 22:48:24] |
We are going to be checking on this as soon as possible.
[2015-12-17 18:15:26] |
The reported problem will be solved in the next release. Also there will be a new Display Above Candles input to accomplish what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-17 18:15:54
