Date/Time: Thu, 26 Dec 2024 18:12:40 +0000
Help with precision Horizontal Levels in version 1269
View Count: 780
[2015-12-15 23:57:29] |
User47706 - Posts: 22 |
I would like to be able to draw a Horizontal Level at a specific price (eg. at 63.59). I am unaware of how to accomplish this being that this tool does not track the price axis when drawn or moved. I would gladly use a Horizontal Line, instead, but I am unable to track the price axis with this tool as well. Should I be able to use the Horizontal Level this way? Am I missing a tool configuration that will enable tracking of the price axis? Do I have the ability to modify a Horizontal Level by setting its price value? Please advise me. Moving a drawn Horizontal Level to a price level is very tedious and always imprecise. |
[2015-12-16 18:09:39] |
You need to set the option to adjust Tool values to the tick size. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#AdjustingDrawingsToTickSize You can also modify the price level of any Chart Drawing: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartDrawingProperties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
